Frequent Contributor II
Problems Routing over Client VPN
I've got an existing network with multiple 620 controllers all connected to a 620 master. Previously I had VPN setup at one of those "hub" locations and it was working fine. I'm now in the process of configuring client VPN into the master. I'm able to authenticate from the Windows 10 native client and also access resources at that location. I'm not able to access resources at any other local controller networks though. If you're local to the network, routing across those tunnels works just fine. Thoughts?
All controllers are running 6.1.3.4-airgroup
The VPN role that clients are assigned is:
1) source nat
2) allow all
3) v6-allow all
Network Engineer | Airhead | Titus 3:5
