Problems after enabling pefng license
after enabling the pefng license on a version 5.0.4.12 Controller I have encountered a few problems.
In "Monitoring/ Clients" Tab I can't see anymore associated/authenticated users. But "Monitoring/ Access Points" shows under .bg Clients and .a Clients there are connected users.
What do I have to mind after enabling pefng license?
Using here wpa2-psk wlans on this related controller. I already have created an user role with a firewall rule "any any permit".
1. Is there any setting which prevents that clients aren't shown under "Monitoring/ Clients" Tab?
2. When using WPA2-PSK how does role derivation works/ where to I have to reference the appropriated user role clients should be assigned after successful authentication?
kokel
MVP
Re: Problems after enabling pefng license
I noticed a small bug regarding monitor > client too.
Can't remember the effected arubaos version, but the 'fix' was to select ipv6 clients and then back to ipv4. Clients showed up this way.
Koen (ACMX #351 | ACDX #547 | ACCP)
Hello koenv,
I can click on IPv4, IPv6, All, everytime "No such station found in the system"
kokel
On CLI:
show user-table
User Entries: 2/2
show user-table station
Station Entries: 17
show ap active shows also a lot of 11g Clients and 11a Clients
What am I doing wrong?
kokel
Kokel,
Please try clearing your browser cache.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
I have read this in several other posts.
Browser cache deleted several times, in different browsers.
But the cli shows the same issue!
user-table entries != clients number from "show ap active" output.
Kokel
Ok.
Did you reboot the controller after adding the licenses?
Yes, the license have only the flag "E".
Is this a production controller?  You might have to do a "write erase" (not write erase all) and start over and see if you have the same issue.
Yes, it's in production.
Temporarily. I have disabled user derivation rules and now I can see all clients like before.
Why do I have to do write erase?
Kokel
