Contributor I
Problems clients get no IP .. mutliple times
Hi there, we are managing the WLAN for one customer, where since we updated IAP 215's to 6.4.3.1 we have found trouble at couple of AP's that returning employees waont' receive an internal LAN IP when entering next morning e.g.
They get a 169.254.x.x. ip..
We have to reboot an AP in order to fix 90% of th eIP problems.. We have 16 AP's in their office.. and we havetheir IT department checked if DHCP IP pool was full, or too long leashes but that is not the issue.
What can be a problem? I have attache dsome screenshots..
Re: Problems clients get no IP .. mutliple times
What did you upgrade from?
Contributor I
Currently we rund the 6.4.2.6-4.1.3.1 - it was an 'needed' upgrade as we had to believe Instant
We came from a version relased somewhere a year ago, it came with shipped IAP's back then - i think 6.4.0.3-4.1.x.
It looks like that client is on the 2.4ghz band.  What is your transmit power on the 2.4ghz band for your access points?  Does it happen to clients on the 5ghz as well?
Contributor I
It happens on clients at 5ghz as well. ilike a macbook air.
Are your clients using encryption?  We need much more information to understand what might be going on here..
I have not seen any reports of clients not receiving ip addresses on that version of code, so we have to troubleshoot this by looking at everything...
Contributor I
Yes they use WPA2 encryption on their SSID. After a reboot the AP provide LAN IP to clients as normal.. it seems to happen after w couple of days..
If you reboot, the environment is changed, so it would fix things.  The question is, how many client do not get ip addresses?  Is it all of them or some of them?  We probably have to turn on user debugging to find out what might be going on here.
Contributor I
We have rebooted all AP's just now since office is empty.
Some clients don't get an IP immediately they enter their working spot, as I can image, 2 AP's provide that trouble - as they did 2 weeks ago.
How can we turn on user debuggin? I placed 5 cleint on the watch list since they where facing that IP problem today.
Please see here:  http://community.arubanetworks.com/t5/Controller-less-WLANs/How-to-enable-packet-trace-to-debug-DHCP-packets-in-Instant/ta-p/179952 or open a case with TAC so that they can get your information and help you debug.
