- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Problems roaming between ap-225's
05-22-2014
02:39 PM
- last edited on
05-22-2014
04:45 PM
by
Jamie E
I'm new to the Aruba's, but I have only access to the web interface managed by our IT department. They are neither inclined or don't have the time to look into this.
The problem for us seems to be when a person roam's from one AP to another. They time out and can't get connected again for several minutes.
We have 4 AP-225. It' happens on OSX and Windows.
Anyone have any ideas?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: Problems roaming between ap-225's
05-22-2014 02:48 PM
Are you using Client Match? Are you sure of your coverage?
Airheads Community - The best place to Connect. Engage. and Learn.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
05-22-2014 03:08 PM
- What type of Authentication are you guys using ?
- How far apart are these APs from each other ?
- Are these APs attached to the same controller ?
- Are these APs in the same AP-Group ?
Victor Fabian
Lead Mobility Architect @WEI
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
05-22-2014 08:52 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
05-27-2014 08:20 AM - edited 05-27-2014 08:49 AM
Client match is on, I can see in the logs, but I might not have accress to ARM config in my interface, or I don't see it and don't know how to pulll up on web interface. But It does show client match in logs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
05-27-2014 08:23 AM
against radius server
20-30 meters apart. spread around outsite offices.
Yes
Yes
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
05-27-2014 08:54 AM
tsd25108 wrote:
What are your min and max power settings (12 min 18 max is a typical starting point)? Are you using band steering? If you're on 6.3.x or above are you using client match?
Max 24
Min 9
That shows up in logs, so I'm assuming it's on.
Client match is on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
05-27-2014 09:14 AM
blackwek,
The Min and Max parameters are located in the diagram below on the controller. You should try the min at 12 and the max at 18 to see if your roaming problems decrease. At issue is that if the power is high clients will "stick" to access points much longer and create the roaming issue that you mention.
Colin Joseph
Aruba Customer Engineering
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
