Frequent Contributor II
Problems updating 6000 controller
Last night I did an upgrade from 5.0.4.12 to 6.2.1.3, after that my captive portal with external radius authentication desn't work.
It shows the login page, we type credentials, click submit and we dont get errors neither any message, but brownsing is not allowed.
Could it be we some but related to captive portal??
Re: Problems updating 6000 controller
Run the following :
logging level security process authmgr
logging level security subcat aaa
And the do show log security 100
Are you using the radius messages making it to the external radius server ?
Confirm that NAD IP address you have define as radius source hasnt change :
Thank you
Victor Fabian
Lead Mobility Architect @WEI
I have seen that my problem is that my aruba controller sends an incorrect :
HTTP/1.1 302 Temporarily Moved to PC workstation containing the incorrect location: ?errmsg=Access denied\r\n, so  workstation is looping trying to get /auth/index.htm/u?errmsg=Access denied.
I have read the same problem here: http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/6-1-3-1-upgrade-captive-portal-now-broken-Broswers-report/td-p/32120
Does anyone is this get solved anyway??
Thank you
I have solved the problem changing the ip address for cp-redirect with command ip cp-redirect-address.
It was pointing to controller loopback address, now if change it to anyone else captive portal works.
I don't know the reason for this behaviour.
