Problems when converting IAPs to CAPs
Hi guys,
I want to convert two IAPs to CAPs to be managed by a controller but I had a problem. One IAP is model 305 and the other is 325, both running firmware 6.5.1.0-4.3.1.3. The controller is model 7005 running firmware 6.4.4.12. The IAPs already have some configuration. When converting the IAPs I got this message
Why do I get this error?
Is it because the IAPs firmware are higher than the controller firmware?
Julián
Re: Problems when converting IAPs to CAPs
Hey, are you having issues with the IAP305? This requires a minimum of ArubaOS 6.5.1.0 or 8.1.0.0 on the 7005 controller. Try upgrading the 7005 to 6.5.1.0 or above first.
http://www.arubanetworks.com/assets/ds/DS_AP300Series.pdf
ACMA, ACMP, ACSA
If my post addresses your query, give kudos:)
Hi zailon0,
Thanks, I didn't check that before. While I upgrade the controller, I have a doubt. I also noticed that the datasheet says
MINIMUM OPERATING SYSTEM SOFTWARE VERSIONS
• ArubaOS 6.5.1.0, 8.1.0.0
• Aruba InstantOS 4.3.1.0
Aside from the controller firmware needed, about Aruba InstantOS 4.3.1.0 I think it means the IAP 305 needs the minimum 4.3.1.0 version, but in the support web site is not found, check this screenshot
Am I missing anything?
Julián
That's where I found the info :) So you will need to upgrade the 7005 controller as the firmware is incompatible.
I'm also unable to see Instant OS 4.3.1.0 as well (HPE may have removed it), Instant OS 4.3.1.1 is available however and does support IAP305, so give this a try.
ACMA, ACMP, ACSA
But I can't find InstantOS 4.3.1.1 either, in the above screenshot Instant firmwares start from 6.4.3.1 on.
Hi zailon0,
After upgrading the controller to 6.5.1.0, the two APs were converted to CAP and managed by the controller. I was able to provision the 325 AP to my AP group, but I have problems to provision the 305 to the same group and I don't know why. CPSec is disabled. Look my screenshots.
Firstly both APs seem to be up
When I click on number 2 in Access Points row I get this
When I click on the 305 AP MAC address I get this
Few seconds later, I get this in Monitoring>Network Summary
If a click on number 1 in Access Points row I get this
The AP 305 is alternating between up and down and the System Status LED is always green intermittent.
Please help, I don't know how to troubleshoot this or the commands to use.
Julián
Hi zailon0,
After upgrading the controller to 6.5.1.0 the two APs have been converted to CAP and are managed by the controller. However, I provisioned successfully the 325 to my AP group, but I have problems provisioning the 305 to the same group, I don't know the reason. CPSec is disabled. Check the following screenshots.
Both APs seem to be up
After clicking on number 2 in the Access Points row I get this
If a click on the MAC address of the 305 AP I get this
After a few seconds the AP is down in Monitoring>Network Summary
If a click on the red number 1 in the Access Points row I get this
I don't know how to troubleshoot this issue or the command to use. Please help.
Julián
Hi zailon0,
The APs is alternating between up and down. The System Status LED is always in green intermittent state.
Julián
The Instant firmware version has two parts, separated by a dash (-):
Release 6.5.1.0-4.3.1.3; means based on controller version 6.5.1.0, and the Instant version is 4.3.1.3. In your screenshot, you can see the -4.3, and scroll to the right to see the full version name (or just click on it).
Thanks for the clarification Herman!
Best regards,
Julián
