Regular Contributor I
Problems with RAP deployment
Hi community,
I´ve problems to deploy my rap3. we ´ve a 7030 controller with code6.4 running.
APs works fine.
The RAP woks fine when I put it into a local ethernet port in our companys lan.
but when I put my 3g Sitck in it the rap comes up and i can see it for short time on my controller it says:
Flag Rc2D and I cannot see it into the controller gui. The 3g stick works fine, I can ping from the rap and I can ping the external ip of the controller...
What is the problem?
Re: Problems with RAP deployment
You should first see if it will work on a wired port on the public internet.  That will rule out an issue with your 3G stick.
#! resolution to this issue:  If the ap-group that the AP is in has a system profile that has an lms-ip in it, remove the LMS-ip.
Colin Joseph
Aruba Customer Engineering
Thanks, what a fast anwer.... :-)
shame on me, it was the lms promlem
