Problems with Radius authentication - WLC
I have a WLC and I have a SSID with Radius Authentication, it was working but after a while it stops working:
I did a tracebuf:
(PA-TB-WCONTROLLER01) #show auth-tracebuf mac 94:65:9c:45...
(PA-TB-WCONTROLLER01) #show auth-tracebuf mac 94:65:9c:45:7a:31
Auth Trace Buffer
May 25 07:13:23  station-up             *  94:65:9c:45:7a:31  40:e3:d6:51:77:90  -  -  wpa2 aes
May 25 07:13:23  eap-id-req            <-  94:65:9c:45:7a:31  40:e3:d6:51:77:90  1  5
May 25 07:13:26  station-down           *  94:65:9c:45:7a:31  40:e3:d6:51:77:90  -  -
May 25 07:18:16  station-up             *  94:65:9c:45:7a:31  40:e3:d6:51:77:90  -  -  wpa2 aes
May 25 07:18:16  eap-id-req            <-  94:65:9c:45:7a:31  40:e3:d6:51:77:90  1  5
May 25 07:18:19  station-down           *  94:65:9c:45:7a:31  40:e3:d6:51:77:90  -  -
May 25 07:18:36  station-up             *  94:65:9c:45:7a:31  40:e3:d6:51:77:90  -  -  wpa2 aes
May 25 07:18:36  eap-id-req            <-  94:65:9c:45:7a:31  40:e3:d6:51:77:90  1  5
May 25 07:18:39  station-down           *  94:65:9c:45:7a:31  40:e3:d6:51:77:90  -  -
Community Manager
Re: Problems with Radius authentication - WLC
Was that client previously successful at authentication?
What is providing the radius service? Can you check to see if the requests are hitting the server?
Airheads Community - The best place to Connect. Engage. and Learn.
Yes, we had no problems before, what additional test can i perform?
is a NPS server, I'll try to get access to that.
Test using the controller aaa test server
Make sure your certificate hasn't expired ?
Have you guys made any changes on the RADIUS server shared key or the NAS IP address on the controller?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Test with aaa test-server is successful but when trying from computer is failing.
The client seems to be failing when the AP/Controller asks for an EAP-ID request.  What client is this and how is the client configured for 802.1x?
