Regular Contributor I
Problems with Split Tunnel SSID
Hi community,
I want to set up a split tunnel ssid on my APs.
We ´ve a 650er Controller running with AOS 6.4.0.3 on it.
I´ve some 105APs and 135APs running.
All my SSIDs working fine but I don´t get the split tunnel SSID up and running.
I´ve create a new SSID I configerd it like this:
http://www.arubanetworks.com/techdocs/ArubaOS_64x_WebHelp/Content/ArubaFrameStyles/Remote_AP/Split_Tunneling.htm
When I set the SSID in the virtual ap profile to split tunnel, the ssid is not broadcasting any more.
Need help. Anyone an idea?
Re: Problems with Split Tunnel SSID
split-tunnel mode is only available for RAPs.  I am guessing that the AP is still a campus AP, which is why the ssid is not coming up.
Try to reprovision the AP as a RAP.
ACCP, ACCX #817, ACMP, ACMX #294
Valued Contributor II
Split tunnel will work with RAP only. are you trying to bring up APs as RAP ? or CAP ?
Please feel free to comeback on this.
Cheers,
Venu Puduchery,
Is there a solution for this, I want a local breakout for this ssid?
you need to provision the AP as a RAP.  If you want all traffic to breakout locally, you can make the ssid bridge, but beware, you need to have cpsec enabled in order to do that.  Enabling cpsec will make all of your aps recertify and cause an outage.
What´s about bridge mode? Is it also only for RAPs?
Bridge mode can be used in campus or remote APs but requires control-plane
security (CPSec) to be enabled.
Tim Cappalli | Aruba Security
HI,
This is for Campus AP :). when you bring up a VAP in Bridge mode, there will not be any GRE tunnel terminating on the controller hence whole traffic from the SSID with bridge mode will be locally bridged to the uplinked switch.
Hope you got some clarity on this.
Cheers,
Venu Puduchery,
Ok, thank´s guys. But there is a problem, at the moment I´ve 2 SSIDs on the APs a Enployee and a Guest SSID. The Guest SSID needs the Controllers Captive portal. When I change the Employee SSID to bridge the guest don´t work with captive portal right?
Correct
