ake
Problems with VIA client
Hi
I have messed up my VIA client.
I get "Virtual Adapter can not be configured" The clients starts and I can point it to either a local controller or to SEEL, but the result is the same. I have tried to remove and install again but the result is the same, rebooting the PC does not help either.
Ake
