Regular Contributor II
Product/AOS matrix
Is there a quick and easy way to compare functionality between AOS versions?
For instance, if you were trying to build a case for upgrading from 5.x.x to 6.x.x what is the easiest way to find out what the differences are between the releases?
Contributor I
Re: Product/AOS matrix
I think a good amount on info on the changes and improvements can be found in the release notes for the first code versions of 6.0.x.x and 6.1.x.x. I have never seen a matrix for this. Of the top of my head some features that I believe were added at some point in AOS 6 were a management dashboard, device type classification, dns named acl's and other.
The compatiblity matrix for AP's can make a case that some newer AP's are not supported on 5.x.x.x. See link below:
