_N_
Occasional Contributor I
Public Transport WiFi
Hi
We have an opportunity to offer WiFi for trains and I've read a number of other threads, but wasn't sure which solution to go with.
My idea was to use IAP with LTE as backhaul.
Something like 205H has a USB port for LTE dongle.
I guess that the same thing can be done on a 225?
What about having some type of a router which supports LTE and has a number of Ethernet ports (and even PoE), so that we need only 1 SIM card per train if we will have multiple APs? Any recommendations?
The idea would be to use Aruba Central to manage all of the APs.
_N_
Re: Public Transport WiFi
Does Aruba have any EN50155 compliant equipment?
     I have the same requirement on EN50155 compliant AP. Any solution for this? Or do we have similar certification?
Hi _N_,
      did you found any solution? Please do share if you found.
Thank You.
Hi!
Did you find anything on this subject? I would also be interested in offering these for a project.
Aruba does not currently have any products certified for EN50155
Jerrod Howard
