Pushing machine certs to Chromebooks using Gsuite
 We are looking to find a solution to push out machine certs to a large  number of K-12 Chromebooks using Gsuite.  Since the Chromebooks can’t talk to AD or MDM we are trying to find out if they can use Gsuite to automatically push the machine certs.
Have verified a process in which we can push the user cert from Gsuite when the user logs in, but have been unable to find a solution for the machine certs, instead of trying to install them all manually.
We also have Clearpass in place.  Anyone run across this?
