MVP
Q: 155Mbps internet line, need to split between 3 VLANS (55Mbps +- to each vlan) | policer-profile
[ Edited ]
I Guys, I have 155Mbps internet line ,that i need to split between 3 VLANS (55Mbps +- to each vlan) Bandwith contract applying to Wi-Fi enviroment only. For LAN / Wired enviroment i understood that i should use Policer profile. anyone can advise on how to config it for 55Mbps for each vlan? AOS 6.2.1.4
This is the default profile | The command ? in CLI:
MVP
Re: Q: 155Mbps internet line, need to split between 3 VLANS (55Mbps +- to each vlan) | policer-profi
"deprecated"
I'm guessing that command is no longer the way to go :)
Haven't actually tested this myself but applying a role with a bandwidth contract to the interface or vlan does not work?
Koen (ACMX #351 | ACDX #547 | ACCP)
MVP
You right. Its seems that in 6.2.1.4 bandwith contract works for wired/untrusted clients
