Q: can I use a AP-105 as controller replacement for 3 AP-125
I like to set up a a home mesh wifi network with 4 APs. One AP-105 and 3 AP-125 I bought  the AP-125 allready and I am wondering if I can use a AP-105 as a controller replacement to manage the AP-125 access points.
Any answer and recommendations are welcome.
Thanks in advance !
Re: Q: can I use a AP-105 as controller replacement for 3 AP-125
AP-125 require a controller.  There is no "instant" version of the AP-125, so they cannot be controlled by an IAP-105.  I hope I am interpreting you correctly.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
