Occasional Contributor I
QBSS Load Element 802.11e not found
When I am doing monitoring on aruba wireless packet, the QBSS Load element are not found in the wireless beacon frame. Is there any setting to enable the QBSS load element?
Re: QBSS Load Element 802.11e not found
http://www.arubanetworks.com/techdocs/ArubaOS_65x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/1CommandList/wlan_ssid_profile.htm?Highlight=qbss-load-enable
Is there any downtime if i enable this features live while other users connecting to the wifi?Can this features enable on the specific Access point?
No downtime.
To enable it on a specifc access point, you would have to create a Virtual AP that has it enabled and apply that ap-specific profile ot the AP.
