Question about AP if controller dies
Dear everyone,
I has 4 sites: Site 1, Site 2, Site 3 and Site 4 (Data Center). Each sites has 1 x Primary internet link to connect to Site 4 and 1 x backup link to Internet.  If primary link has problem, users connect to Internet through backup link.
I am going to propose the number AP:
Site 1: 10 x AP-115 and Secondary DC.
Site 2: 5 x AP-115 and Secondary DC
Site 3: 3 x AP-115 and Secondary DC
Site 4: 1 x Wireless Controller 3200 and Primary DC
Site 4 (Data Center) can point to point to Site 1, Site 2, Site 3. Wireless Controller put at Data Center to manage all APs at Site 1, 2,3. Site 1, Site 2, Site 3 can't connect together.
Questions:
- When the connection to controller is lost, AP can automatically authenticate users locally with Secondary DC and allow data traffic go out to Internet through back-up link at each site.
Which is the best solution for high availability without Redundant Controller?
Khang
Trusted Contributor I
Re: Question about AP if controller dies
You need a redundant controller in order to terminate the AP-115's should the primary controller fail.  Otherwise, the APs will stop broadcasting the SSID.
You could configure RAPs instead and use the Remote AP Operation Setting to broadcast a backup WPA2-PSK network that uses the backup Internet link.
Finally, you could use IAP-115's instead and configure each site as an instant cluster (no controller needed).  Then you're not reliant on the main data center's controller being available.
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
Thank you for your response.
I want to make clearly about the answwer: "You could configure RAPs instead and use the Remote AP Operation Setting to broadcast a backup WPA2-PSK network that uses the backup Internet link"
On AP of Aruba, we can configure Remote mode or we must use RAP?
Thanks & Best regards,
Khang
Any AP can be configured as a RAP, so the option should be available if you
configured your APs as RAPs.
I think going with IAPs is a better solution since you're not dependant on
a controller and you don't have to tunnel your traffic all the way back to
the data center, unless that's a requirement.
Thank you for your support.
My customer required Wireless Controller and he can manage 3 sites with Wireless controller.
Khang
