mke
Contributor II
Question about converting jl016a to campus AP
I have an instant AP that looks like ARBUA 225 but it is HP virtual controller ap hp 365. What is the default pasword to this bacause after factory reset admin/admin does not work
Do I have to convert it somehow to make it work as a regular AP if yes how?
mke
Contributor II
Re: Question about converting jl016a to campus AP
Can I flush my JL016A (basically it is Aruba 225) if I wont get the password and reset does not help?
Where can I get the image from?
