Occasional Contributor I
Question about role assignment for radius authenticated users.
I have successfully setup radius authentication for my AD users. However, users are being assigned a guest role instead of the logon role that is set in the AAA profile for the radius authentication. I cannot determine what is superseding the role.
Re: Question about role assignment for radius authenticated users.
User "show user-table ip <ip address of user>" to see how the user got that role.  In your AAA profile, the default 802.1x role should determine your user's role.
Ok i see the following in the reply
Role Derivation: default for authentication type 802.1x
then
Role assigment - L3 assigned role: n/a, VPN role: n/a, Dot1x cached role: n/a
Current Role name: guest, role-how: 1, L2-role: guest, L3-role: guest
My AAA profile is set for Logon. I have looked at the 802.1x seetings but do not see where to assign the role. I am using mschap for 802.1x.
In the AAA profile, what roles is the default 802.1x role set to?
default-dot1x is set to logon.
Type show "user table verbose" and it will say in one column which AAA profile is being used (expand your terminal to full size to see). This is just to make sire you are referring to the correct 802.1x profile.
In the auth column I see 802.1x and the Profile column shows the radius profile i created, but I have verified that logon is the role i have set for that AAA profile. However, the user roles are still guest.
Okay.  Do you have the policy enforcement firewall license installed?
We purchased and installed 1 PEF license before we realized we needed one for every ap. I removed the initial license.
If you do not have the PEF license every authenticated user will end up in the guest role.
