Question regarding ANT-AP-MNT-1 pole mount kit
Does anyone know the dimensions of the bracket and range of pole sizes the ANT-AP-MNT-1 pole mount kit can accommodate? I have a project that I need to spec mounting for. Thanks, Ernie
Re: Question regarding ANT-AP-MNT-1 pole mount kit
I've found the answer to the guestion. It takes a 1" to 4" pole. There's just one clamp so vertical dimensions aren't an issue. Ernie
Aruba
Here are a few pictures of the ANT-MNT-1 installed.
It is a very sturdy, versatile az-el mount.   Can also be used in a wall configuration by lagging one half into a structure.
-cl
Contributor II
Thank you for the pictures. I need to see how they look planning to order a few for a project.
