Frequent Contributor I
Question regarding Bandwidth contract. HELP
I want to apply the bandwidth contract for the wireless users . Just need to know whether i have to apply the bandwith contract by editing the just initial role else on both " initial as well as authentication role ?
Re: Question regarding Bandwidth contract. HELP
You would really ONLY have to do it for the role that the user gets POST-Authentication - Guest.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Dear Sir,
You mean, we only apply the bandwidth contract on the initial role else after the initial role ??
In my case initial role is logon and defualt role is logon ?
If you know what role a user gets after he authenticates, that is the role you apply the bandwidth contract to.  If you are not sure what role that is, do not use a bandwidth contract, period.
Now Understood
Thanks for help... :)
