Frequent Contributor I
Question regarding captive portal authentication.
Captive portal is working fine... I enabled the user as well as guest at L3 profile
Although the registered user can provide username & password for authentication and this portal login are also for the guest authentication.
My Question is, is there any option to configure the username and password for guest user portal login as well ???
Re: Question regarding captive portal authentication.
Under the authentication > Layer 3 auth > captive portal auth > <name of the captive portal you are using >
Uncheck the guest login and leave user login
Thank you
Victor Fabian
Lead Mobility Architect @WEI
I know that... after disabling the guest login.
But Is there any other option for guest portal login insteas of email ?
This should help you out :
https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/R-1649
Thank you
Victor Fabian
