Question: wpa2-aes connect problem
Hi  .
I used Alcatel firmware 6.3.1.4 and i attempted to connect to WiFI with wpa2-aes applied.
However, only iPhone was connected.
android 5,6 and win10 is fail.
Anyone know this issue?
why 6.3.1.4 make fail to connect Wi-Fi with wpa2-aes applied?
( I used internal radius)
Re: Question: wpa2-aes connect problem
Hi Insang,
Please enable user-debug for couple of clients & provide the following outputs:
config#logging level debugging user-debug <mac-address of user>
#show  authetracebuf count <>
This could be related to TLS 1.2 version for which the fix was given in 6.3.1.20.
But we need logs to determine that.
Hwang wrote:
Hi  .
If you are using internal radius that means that you are using EAP-Termination.  Did you replace the internal radius server certificate with something that is valid?  6.3.1.4 is very old....
thank you reply and sorry i'm late..
a0:b4:a5:8b:f3:e5 is my android6.0 phone)
(OAW-4306G) #show clock
Mon Jul 24 04:24:21 PST 2017
(OAW-4306G) #show auth-tracebuf count 20
Warning: user-debug is enabled on one or more specific MAC addresses;
only those MAC addresses appear in the trace buffer.
Auth Trace Buffer
Jul 24 04:19:04 client-finish -> a0:b4:a5:8b:f3:e5 00:24:6c:7f:0a:10/802.1x_kbs - - invalid tls version
Jul 24 04:19:36 eap-term-start -> a0:b4:a5:8b:f3:e5 00:24:6c:7f:0a:10/802.1x_kbs - -
Jul 24 04:19:36 station-term-start * a0:b4:a5:8b:f3:e5 00:24:6c:7f:0a:10 1 -
Jul 24 04:19:36 client-finish -> a0:b4:a5:8b:f3:e5 00:24:6c:7f:0a:10/802.1x_kbs - - invalid tls version
Jul 24 04:20:08 eap-term-start -> a0:b4:a5:8b:f3:e5 00:24:6c:7f:0a:10/802.1x_kbs - -
Jul 24 04:20:08 station-term-start * a0:b4:a5:8b:f3:e5 00:24:6c:7f:0a:10 1 -
Jul 24 04:20:08 client-finish -> a0:b4:a5:8b:f3:e5 00:24:6c:7f:0a:10/802.1x_kbs - - invalid tls version
Jul 24 04:20:19 station-up * a0:b4:a5:8b:f3:e5 00:24:6c:7f:0a:10 - - wpa2 aes
Jul 24 04:20:19 station-term-start * a0:b4:a5:8b:f3:e5 00:24:6c:7f:0a:10 1 -
Jul 24 04:20:19 client-finish -> a0:b4:a5:8b:f3:e5 00:24:6c:7f:0a:10/802.1x_kbs - - invalid tls version
Jul 24 04:20:50 eap-term-start -> a0:b4:a5:8b:f3:e5 00:24:6c:7f:0a:10/802.1x_kbs - -
Jul 24 04:20:50 station-term-start * a0:b4:a5:8b:f3:e5 00:24:6c:7f:0a:10 1 -
Jul 24 04:20:50 client-finish -> a0:b4:a5:8b:f3:e5 00:24:6c:7f:0a:10/802.1x_kbs - - invalid tls version
Jul 24 04:21:22 eap-term-start -> a0:b4:a5:8b:f3:e5 00:24:6c:7f:0a:10/802.1x_kbs - -
Jul 24 04:21:22 station-term-start * a0:b4:a5:8b:f3:e5 00:24:6c:7f:0a:10 1 -
Jul 24 04:21:22 client-finish -> a0:b4:a5:8b:f3:e5 00:24:6c:7f:0a:10/802.1x_kbs - - invalid tls version
Jul 24 04:24:24 station-down * a0:b4:a5:8b:f3:e5 00:24:6c:7f:0a:10 - -
Jul 24 04:24:24 station-up * a0:b4:a5:8b:f3:e5 00:24:6c:7f:0a:00 - - wpa2 aes
Jul 24 04:24:24 station-term-start * a0:b4:a5:8b:f3:e5 00:24:6c:7f:0a:00 1 -
Jul 24 04:24:24 client-finish -> a0:b4:a5:8b:f3:e5 00:24:6c:7f:0a:00/802.1x_kbs - - invalid tls version
and
(OAW-4306G) #show log all 10
Jul 24 04:24:57 authmgr[2290]: <132162> <ERRS> |authmgr| Station a0:b4:a5:8b:f3:e5 00:24:6c:7f:0a:00 sent with unsupported TLS client version 771
so..is this problem android or  firmware image?
i think 6.3.1.4 can't support TLS1.2 version , is that right?
and it only solve upgrade image ?
(  i aleady talk to my customer "you need upgrade " )
thank you for help me
i know 6.3.1.4 is very old . but my customer use AP 70 .
So I will tell the customer that we need to upgrade the firmware and change the access point.
um... will this link help me? " what is EAP-Termination "
https://community.arubanetworks.com/aruba/attachments/aruba/unified-wired-wireless-access/6140/1/EAP-TLS%20Termination-2.docx
The issue is related to firmware not supporting TLS version 1.2 when EAP-Termination is on controller.
Please use one of the following options :
1. Use external radius server & disable EAP-termination on controller. Ensure that external server is using a valid server certificate.
2. In case you don't have radius server & need to use controller's internal  db for authentication , we need to upgrade the controllers to 6.3.1.20 or above to support new TLS version.
The following link has more info on 802.1x/EAP termination:
https://community.arubanetworks.com/t5/Controller-Based-WLANs/How-does-dot1x-termination-work/ta-p/178566
I appreciate it .
Thank you VERY much~!
