Quoting outdoor antenna question
  • 1.  Quoting outdoor antenna question
    Posted Oct 08, 2013 09:00 PM
    Hello everyone
    I got a question regarding this as i never quoted an external AP
    In this case it would be a AP 175P with 70  and 60 degrees antenas
    I see so options and i dont know what i should add...
    Anyone can help?
  • 2.  RE: Quoting outdoor antenna question
    Posted Oct 08, 2013 09:07 PM
    You are on the right track.
    I would increase the cable count to '4'.  As the antennas you have selected require two cables each.  You have the right ones selected.
    The LARs are good, the installation kit is nice to have.
    Make sure you have POE+ available to power the unit (it has an internal heater)
    JF
  • 3.  RE: Quoting outdoor antenna question
    Posted Oct 08, 2013 09:16 PM
    Like this?
  • 4.  RE: Quoting outdoor antenna question
    Posted Oct 08, 2013 09:22 PM
    Sure, That would be a good config as long as you can have the Power Injector 'indoors'.
    FYI, the other Power injector options available are suitable for outdoor deployments.   Those are pricier, however give you more deployment options in terms of mounting the injector(s).
    JF
  • 5.  RE: Quoting outdoor antenna question
    Posted Oct 08, 2013 09:28 PM
    YEah the power injectors are going indoor! where the switch is.
    Thanks!!
    Cheers
    Carlos
  • 6.  RE: Quoting outdoor antenna question
    Posted Oct 08, 2013 09:32 PM
    Last question
    Should i put one of these?As far i see this is a Aruba Kit with weatherproof connector assembly to attach cable to (plastic) RJ45 interface on outdoor AP models
    We will be using outdoor ethernet cables to reach the antennas(less than 100m) quote3.PNG
  • 7.  RE: Quoting outdoor antenna question
    Posted Oct 08, 2013 09:53 PM
    Good catch!!
    Yes one of those would be good to use per AP, waterproofing definately good.
    JF
  • 8.  RE: Quoting outdoor antenna question
    Posted Oct 08, 2013 10:09 PM
    Thanks!!!
  • 9.  RE: Quoting outdoor antenna question
    Posted Oct 10, 2013 11:30 PM
    Is this for an outside location where temperature could go below -30Celcius in the winter? If yes, you might think to switch to AP-175AC which can go down to -40. This one also require the AC cable.
  • 10.  RE: Quoting outdoor antenna question
    Posted Oct 10, 2013 11:39 PM
    Carlos is from Panama...
    I hope he never see's Neg anything ;-)
    JF
