Having recently deployed ArubaOS 6.2.1.2 on 2 x Aruba 7240 controllers I noticed some strange behaviour with the "ip radius source-interface" command. When this command is specified on the controllers (a master and a local with different vlan interfaces) everything works without issue.
However, if either controller is reloaded this command seems to be cleared from the configuration and the controller reverts back to using the interface determined by routing. Has anybody else come across this problem?
The same appears to happen if you specify the NAS IP address on each controller.
David
#7240
