RAP-109 Mount/Stand
Hello, a customer has a inventory of old RAP 109s. I am looking to procure mounts for these, specifically the mount that comes in the box with the AP. (seen  here) The ordering guide only lists the SKU for the ceiling mounts. I was wondering if anyone knows the SKU for that desktop mount/stand and if it was orderable or not.
Thanks for any help.
Re: RAP-109 Mount/Stand
Those are not orderable separately, they only come with the AP. There's no J-number associated with them. Not sure where to look, possibly ebay, etc. Unfortunately without a J number we don't have a simple way to bulk order additional desk stands.
Jerrod Howard
