Frequent Contributor II
RAP 155 without cpsec
Hi all, I have a requirement to set up some RAP 155's but cannot use cpsec because of the age of some of the AP's, can these be used with a pre shared key ?
ACMA/ACMP
Re: RAP 155 without cpsec
In a campus setting, no access points require cpsec. Are you setting up raps?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Colin, yes sorry thats what im after, RAP 155's
ACMA/ACMP
You can use certificate based RAP authentication for the newer access points, and IKE preshared/username password for the older RAPs at the same time.  The older APs would not use the RAP whitelist.
Colin, yes ok I get this. These are IAP's that you convert to RAP's.  So I guess to give them the correct boot info I need to first convert to CAPS, then provision them on the controller as RAPS and then deploy.
If this is the case I assume under the provisioning page that I set the controller IP as the public FW IP ?
ACMA/ACMP
You can convert them directly to Remote APs.  No need to convert them to CAPs first.
http://www.arubanetworks.com/techdocs/Instant_41_WebHelp/InstantWebHelp.htm#UG_files/IAP_maintenance/ConvertingIAPtoRAP.htm?Highlight=convert
You do need to add the IAPs mac address to the RAP whitelist on the Aruba Controller.  The ip address you put into the IAP's convert box should be the public ip address of the controller.  That ip address will be burned into the flash and that is the ip address the RAP will always attempt to connect to after conversion, unless it is reprovisioned.
