fmo
Contributor I
RAP-2G Failed to connect with Controller
Guys,
Am referencing this solution
http://community.arubanetworks.com/t5/ArubaOS-and-Controllers/Rc-error-ike-xauth-authorization-failed/m-p/12115#M4994
I seem to have the same error but for some reason, I cannot see the solution given by cjoseph. Perhaps someone here can help me (since cjoseph is not currently online) and its rather urgent.
Am getting the same error
Sep 2 08:25:45 <localdb 133006> <ERRS> |localdb| User 00:0b:86:c3:50:9d Failed Authentication
Sep 2 08:25:45 <isakmpd 103048> <ERRS> |ike| IKE XAuth failed for 00:0b:86:c3:50:9d
fmo
Aruba
Re: RAP-2G Failed to connect with Controller
To add to the whitelist, you'll need to go to Configuration > Wireless > AP Installation > Whitelist and add the mac into there.
Make sure you have a local nat pool configured as well.
:smileyhappy:
ACCP, ACMP, ACMX #294
mclarke@arubanetworks.com
fmo
Contributor I
I had alresdy done that, but my AP was still not visible under the ALL APs tab. I had to restart the Controller several times...then it worked.
Thank you.
