Super Contributor I
RAP-2WG Not Working with AOS 6.1.2.5
Does RAP-2WG work with Aruba3600-US Version 6.1.2.5?  A RAP-2WG after reset showed up in this controller with flags "IL" (inactive, unlicensed).  I do have enough AP license.  However, if this RAP-2WG force to an AOS 5 controller, it worked normal.
Trinh Nguyen
~Trinh Nguyen~
Boys Town
Re: RAP-2WG Not Working with AOS 6.1.2.5
You may need to upgrade the backup partition. I know there was an issue with this, especially if it was on 3.4rn at one point in time. Have a look at this: http://community.arubanetworks.com/t5/Command-of-the-Day/COTD-apflash-backup-partition-or-how-do-I-upgrade-my-RAP5/m-p/5829/highlight/true#M258
See what the partitions have on them.
Zach Jennings
After you check the provisioning partition version, make sure you have it in your whitelist.
Super Contributor I
Thanks zjennings, using the  “show ap image version”, I found the RAP was stuck in AOS5.  Using the instruction in COTD, it flash the new image and now showed up for the provisioning.  Thanks all for your help!
Mike, we do not use the "white list".  All APs must be provisioned by IT and document before hand out.
Trinh Nguyen
~Trinh Nguyen~
Boys Town
Occasional Contributor I
Re: RAP-2WG difficulties in configuration during install of hotel project in china
is RAP-2WG suitable for hotel application ??
we just installed one lot RAP-2WG in a hotel room for guest wifi access
we failed to configure the ap with the 3400 controller in past 7 days but no success
some AP work but some APs are not working..
some experienced users told us that we selected wrong AP model for hotel room application.
we need advice from experts??
The RAP2WG is specifically for the small office home office.  It is not plenum-rated and does not support POE so it is not appropriate for the hotel.  TheAP93 or the AP93H would be a better fit:
AP93  http://www.arubanetworks.com/pdf/products/DS_AP90Series.pdf
AP93H http://www.arubanetworks.com/products/access-points/ap-93h/
Finally , we can use most of the RAP-2WG in the hotel rooms project. 75% of the APs (total 144 pcs) are working fine yesterday.
However , new problem comes
The 3400 controller stucks and need reboot manually.
The os version is 6.1.3.3.
Any suggestion ???
We solved the crash problem by down graded the os to 5.0.3 from 6.1.3.  Everything resumes to normal.
I would like to ask for the procedure or command to restart ap in specific period automatically.
