Regular Contributor II
RAP-2WG issue with AOS 6.3.1.1
Hey Guys,
Just upgraded a 620 Controller to Release 6.3.1.1 and I noticed my RAP-2WG just died.
A "datapath session" command shows the session from my RAP to the Wireless Controller but I don't see it come up.
Wireless Controller was previously on Release 6.1.X.
Any one seen this issue before?
Aruba
Re: RAP-2WG issue with AOS 6.3.1.1
In the datapath session table output, are there any "D" for deny's ?
I don't believe I saw one.
(Aruba620BurlingtonMaster) #show datapath session | include 4500
192.168.100.61 99.227.188.4 17 4500 49793 0/0 0 0 2 1/8 1a 0 0 FY
192.168.100.61 99.227.188.4 17 4500 49795 0/0 0 0 0 1/8 3 0 0 FY
99.227.188.4 192.168.100.61 17 49795 4500 0/0 0 0 0 1/8 3 0 0 FC
99.227.188.4 192.168.100.61 17 49793 4500 0/0 0 0 1 1/8 1a 0 0 FC
Start debugging:
config t
logging level debugging security subcat ike
logging level debugging security process aaa
logging level debugging security process authmgr
logging level debugging security subcat l2tp
logging level debugging security subcat vpn
 Connect the RAP, then type "show log security 50" and see if there are any error messages that correspond to that RAP.
To turn of debugging:
config t
no logging level debugging security subcat ike
no logging level debugging security process aaa
no logging level debugging security process authmgr
no logging level debugging security subcat l2tp
no logging level debugging security subcat vpn
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
cjoseph wrote:
Start debugging:
config t
config t
Nov 3 07:50:30 :103061: <ERRS> |ike| 99.227.188.4:49152-> find_listening_transport: virtual transport for address 192.168.100.61 not found in virtual_listen_list
Nov 3 07:50:30 :103063: <DBUG> |ike| 99.227.188.4:49152-> transport_handle_messages Could not find transports for IP-Port:c0a8643d:4500, Re-init the transports
Nov 3 07:50:35 :103061: <ERRS> |ike| 99.227.188.4:49152-> find_listening_transport: virtual transport for address 192.168.100.61 not found in virtual_listen_list
Nov 3 07:50:35 :103063: <DBUG> |ike| 99.227.188.4:49152-> transport_handle_messages Could not find transports for IP-Port:c0a8643d:4500, Re-init the transports
Nov 3 07:50:40 :103061: <ERRS> |ike| 99.227.188.4:49152-> find_listening_transport: virtual transport for address 192.168.100.61 not found in virtual_listen_list
Nov 3 07:50:40 :103063: <DBUG> |ike| 99.227.188.4:49152-> transport_handle_messages Could not find transports for IP-Port:c0a8643d:4500, Re-init the transports
Nov 3 07:59:38 :103061: <ERRS> |ike| 99.227.188.4:49199-> find_listening_transport: virtual transport for address 192.168.100.61 not found in virtual_listen_list
Nov 3 07:59:38 :103063: <DBUG> |ike| 99.227.188.4:49199-> transport_handle_messages Could not find transports for IP-Port:c0a8643d:4500, Re-init the transports
Nov 3 07:59:43 :103061: <ERRS> |ike| 99.227.188.4:49199-> find_listening_transport: virtual transport for address 192.168.100.61 not found in virtual_listen_list
Nov 3 07:59:43 :103063: <DBUG> |ike| 99.227.188.4:49199-> transport_handle_messages Could not find transports for IP-Port:c0a8643d:4500, Re-init the transports
Nov 3 07:59:52 :103061: <ERRS> |ike| 99.227.188.4:49201-> find_listening_transport: virtual transport for address 192.168.100.61 not found in virtual_listen_list
Nov 3 07:59:52 :103063: <DBUG> |ike| 99.227.188.4:49201-> transport_handle_messages Could not find transports for IP-Port:c0a8643d:4500, Re-init the transports
Haven't seen this error type before. Any idea what the above means?
Do you have your RAPs pointing at a VRRP?
No I don't. This is really strange.
Don't know if resetting the RAP to factory default will help. I doubt cos, as you can see, the RAP is definitely attempting to establish a session to the Controller.
What do you think?
Please open a case, because it has been seen before, but only with a vrrp.
Please do the following :
show  vpdn l2tp local pool - make sure you have the RAP pool active
show  crypto ipsec sa - ipsec phase 1
show  crypto isakmp sa - ike phase 1
show user-table verbose
show  rights ap-role
How are you configuring this RAPs ?  RAP whitelist ?
show  local-userdb-ap
How are your RAPs reaching the controller ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
