RAP-2WG issue with AOS
We are having problem after upgrading a Aruba650 Controller from AOS to AOS
All RAPs Can't be connected To Controller
After Resetting the RAP-2WG to factory defaults does not resolve the issue.
The RAPs show as upgrading in their status,and RcI Flags then they just reboot and try to upgrade again.
My RAP-2WGs have AOS on the backup partition.
Re: RAP-2WG issue with AOS
The last version of ArubaOS that supports the Rap2WG is ArubaOS 6.3  http://www.arubanetworks.com/support-services/end-of-life/#AccessPoints
Colin Joseph
Aruba Customer Engineering
RAP-2 is not supported on 6.4
Tim Cappalli | Aruba Security
