RAP 3 and rap109 in Instant MODE
When its recommended using this type of solution but in instant mode not in RAP mode?
For example if i got an hotel i which they got 200 rooms and they want a cheap solution that give them ports on all the rooms and you know per AP there wont be more than 4 users connected to it.
You will have many cluster managed by the Airwaves.
Is there are any recommendation like dont use them as instant mode if you know there will be  like x ammount of clients connected to each one... or dont use it if you will have a cluster with more than x ammount of APs or something!
Same with the RAP109 when i should not use that as instant solution?
I bealive that if it has instant on it its beacuse its meant to use in some kind of situtation, and i want to know what kind of situation is that?
Cheers
Carlos
Alternetworks Corp
Re: RAP 3 and rap109 in Instant MODE
Anyone?????
Alternetworks Corp
Noone????
guest this has not been tested....
Alternetworks Corp
