RAP-3's coming up as air monitors after 6.3.1.4 upgrade.
Anyone have any ideas why my RAPs would be coming up as air monitors after upgrading to 6.3.1.4? They were working fine pre-upgrade.
Re: RAP-3's coming up as air monitors after 6.3.1.4 upgrade.
Are those under the same AP-Group and Controller ?
Confirm how your RF-Profile is configured as an Air Monitor ?
Did you do guys do a save config before rebooting the controller ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
same AP group, same controller, we did save the config before rebooting and they are set to ap-mode.
Do you have any ap specifc configuration ?
Are all the RAPs under that AP-Group showing up as Air Monitor  when you run the show  ap  active type air-monitor ?
Thank you
Victor Fabian
I did have ap-specific configuration and it was configured incorrectly. Up and working now. Thanks for your help!
Another mark for the user error column. :)
-Chris
