RAP-3WN for Huawei 3276
Can anyone tell how to setup a RAP-3WN using a Huawei 3276 usb Modem? The controller for remote APs is in a dmz with OS 6.3.1.5. This is the first time i am doing it, please explain step by step.
Thanks for the help!!!
MVP
Re: RAP-3WN for Huawei 3276
Immi,
The Huawei 3276 has a minimum software releas of 6.4 for controller and 4.1 for Instant.
Provisioning parameters:
usb_type=huawei-cdc
cellular_nw_preference=auto
usb_dev=0x12d11506
There are multiple versions of the E3276, not every type has been tested. The E3276-150 seems quite common and is reported to work.
Herman
hrobers,
Thank you, will upgrade the image and try it out.
I upgraded the image to 6.4 and the RAP is up in the Remote controller, but the USB doesnt seem to work. I provided the following details in the USB parameters.
usb_type=huawei-cdc
usb_dev=0x12d11506
PPP username= Orange
PPP Password = ********
Do I need to specify other parameters as well:
TTY Device data path
TTY Device control path
Initialization String
Modeswitch
if i have to give these, what would be the values for it.
Thanks for your time and support...
Immi
MVP
Those parameters are optional, you should be able to leave them empty.
If it does not work for you, please open a TAC case.
Herman
