Moderator
RAP 5WN 3g backup connection
Hello
One of our customer has asked us to validate the configuration of a 3g USBmodem to be used as backup connection for both 620/650 controllers and for RAP5 access points. We've been able to successfully configure the controller (620) to gain internet access through the 3g USBmodem but have so far been unable to do the same with the RAP5. We're using the same configuration parameters, and have tried all the possible combinations of ttyUSBx but we still haven't managed to get it working. Is there anything else that we should take into account?
Details:
ArubaOS version - 6.1.2.8
USBmodem - Acatel X225L
Cellular params configured (and working) on the controller:
dialer group euskaltel_esp
  init-string AT+CGDCONT=1,"IP","internet.euskaltel.mobi"
  dial-string ATDT*99#
cellular profile Alcatel
  vendor 1bbb product 17
  serial 1234567890ABCDEF
  dialer euskaltel_esp
  user CLIENTE password EUSKALTEL
  tty ttyUSB4
  driver option
Thanks for the help
Best regards
Samuel Pérez
ACMP, ACCP, ACDX#100
If I answerd your question, please click on "Accept as Solution".
If you find this post useful, give me kudos for it ;)
Re: RAP 5WN 3g backup connection
Samuel Perez,
The driver support for the RAP5 and the 600 series controller is not always the same.  Please open a TAC case, so someone can troubleshoot.  I do not see that specific modem on our supported list, so we might want to TAC to attempt to get those parameters for you.
Moderator
Thanks, we'll do as you say.
Regards
Samuel Pérez
