Frequent Contributor I
RAP-5WN and RAP2-WG with ArubaOS 6.4
Will RAP-5WN and RAP2-WG APs not work if I upgrade to AOS 6.4? I want to purchase AP205s, but they will only run on AOS 6.4. Don't want to upgrade to 6.4 for the purpose of getting AP205 if that will kill my RAPs from fucntioning.
Tony Maruqes
Re: RAP-5WN and RAP2-WG with ArubaOS 6.4
The last supported code for the RAP-5 is 6.3. If you upgrade to 6.4, those will not boot.
Tim Cappalli | Aruba Security
Hi Tim,
Thanks for the confirmation. I would safely assume that AP205 won't boot on 6.4 code correct?
Tony Marques
The 205 will not boot with a code older than 6.4.1
