RAP Mix two opertation Mode
Dear All
just to be sure for 100%
in RAP mode can i have two VAP (in the Same APGroup)
one with split-tunnel operation mode
the second with bridge (always or backup oparation mode).
Regards.
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
Re: RAP Mix two opertation Mode
Correct.
Yes, you can.
Tim
Tim Cappalli | Aruba Security
