RAP and PCI compliance
I am wondering if anyone can give me some information on the RAP's and it's ablility to be PCI compliant in the following configuation.
I will have a DSL/3g/4g connection into a RAP5 the RAP will provide normal Wireless monitoring and connectivity for NON CDE data. 1 port on the RAP5 will be set to tunel all traffic back to datacenter and will have PCI data on it.
See the attached PDF for a visual of what i am looking at.
Trusted Contributor I
Re: RAP and PCI compliance
Statefull firewall inspection (check)
Segmentaiton of CDE and non-CDE data (check)
WPA/WPA2 encryption on CDE network (check I assume??)
Assuming you're also doing rogue detection you should be compliant.
This question was posted a while ago, so I assume you figured it out.  Can you reply back with your experience in making sure your network was PCI compliant?
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
