Occasional Contributor I
RAP at Remote office
I have a RAP 5 connected to and Inter Connection. I am getting access back to the office and the Corporate SSID is visible and working. I was wondering if the wired ports on the RAP can be programmed to be used by the internet Connection DHCP at the local office to provide connectivity on the local lan?
Bill
Valued Contributor I
Re: RAP at Remote office
It can.
Most of the settings are in the wired port profile applicable in your AP group (under the interface number sub-configuration). You should be able to set the "Forward mode" to bridge if you simple want the RAP to bridge the port straight to the ADSL router (or flat LAN). You'll also see other settings in there in case you want to get more complex with it. Under an AP wired port profile, you can also apply a firewall role to the connection if you like.
Kudos appreciated, but I'm not hunting! (ACMX 104)
