Super Contributor II
RAP connection error
I have upgraded a controller to 6.3.1 and getting these error messages from the RAPs trying to connect -
Jun  1 10:32:25  stm[1652]: <304001> <ERRS> |stm|  Unexpected stm (Station management) runtime error at papi_handler, 1491, Invalid message type 3144 ip =, from 8451
Any idea what this means?
Re: RAP connection error
By itself it does not automatically mean anything.  What did you upgrade from?  type "show log security 50" to see if you see anything.
Colin Joseph
Aruba Customer Engineering
HI Matt,
Even the syslog message guide does not provide much.
304001 Unexpected stm (Station management) runtime error at [func:%s], [line:%d], [data&colon;%s]
Description: Unexpected condition occurred in the station manager (stm)
Recommended Action: Contact your support provider
Like cjoseph said, see in the security logs if you see anything and post the output here.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACMP
[If you found my post helpful, please give kudos!]
I have reverted back to the old code for the moment, but will run a test later today.
If its just one rap i would factory default the rap and try provisioning it again... i mean anyways it will get all the config and it just take a few mins doing that...
If you got aruba activate even better everything will be automatically(i mean if it rap3 and onward)
Alternetworks Corp
Unfortunately it is a number of 105 RAPs on an MPLS so cannot be defaulted and no activate available.
