RAP failover to same controller, different interface?
  • 1.  RAP failover to same controller, different interface?
    Posted Dec 14, 2011 06:29 AM
    I have controller with two WAN connections, both own interface and static IP. Can I use LMS to create failover trough different WAN interfaces to same controller in case another WAN connection fails?  Or is this doable at all?
  • 2.  RE: RAP failover to same controller, different interface?
    Posted Dec 14, 2011 06:35 AM
    Not sure if this is doable, because despite having two interfaces, the controller will only have a single best route back to the RAP out of a single interface.  That can certainly change, but ONLY if the physical controller interface goes down.  So if you have an upstream failure of a WAN connection, for example, the controller will not detect it.
  • 3.  RE: RAP failover to same controller, different interface?
    Posted Dec 14, 2011 06:54 AM
    Ah, thats a bit turn off. Most likely its the upstream DSL link that fails than ethernet link between controller and DSL modem. I suppose I'll settle with some persistent options then.
  • 4.  RE: RAP failover to same controller, different interface?
    Posted Dec 14, 2011 04:39 PM
    If you could do OSPF between the controller and your upstream routers and they can give you default route, you may be able to work something out.
