RAP implementation - Site with two ways to controller.
Hi Guys, please I need a help with the following scenario.
I have a romote site with two ways to the main site where the controlle will be installed, I think that the best way is to implement this solution with remote AP on the site B. But, I have a LAN to LAN link and the ADSL as a backup link.
My doubt is related to the RAP configuration. How can I configure the RAP to find the controller and close the tunnel, independently of the link?Slide3.JPG
Re: RAP implementation - Site with two ways to controller.
You will need policy-based routing in your infrastructure to do what I think you want to do.  If you giave the RAP a static ip address and the gateway of the router that will send its traffic where you want, it might work outbounds, but might not work inbounds.  I think this needs to be solved on the infrastructure side so that your traffic will not be asymetric.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
