Frequent Contributor I
RAP leaks internal IP Address', MAC Address' and EAPOL information
When monitoring the switch port that the WAN Interface connects to, packet captures show that MAC address', IP Address', etc are gathered for devices connected directly to the RAP. Shouldn't this information be encrypted? The uplink switch shouldn't see those MAC Address' in it's CAM table, but yet it does. Any dieas?
Tony Marques
Re: RAP leaks internal IP Address', MAC Address' and EAPOL information
What forwarding modes are you using?
Tim Cappalli | Aruba Security
Is setup tunneled/Bridge ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
I assume it's under AP Configuration > AP Group > Edit "xxx" > Profiles > AP > Ethernet interface 0 port configuration > Wired AP:
I have Forward mode = tunnel and Trusted not checked and Broadcast checked
Tony Marques
tmarques,
Please open a TAC case so that what you are seeing can be understood.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
