Our RAP Local pool is becoming too small.
We have 2 masters and 4 localcontrollers. When a RAP boots it will be directed to one of the locals. On all our controllers we have configured the same ip range for the localpool. We used a free subnet on our wired LAN for our pool.
Is it possible to change the range without problems with our active RAP's ? In that case the range will overlap with a subnet on our wired LAN, does this give routing problems? What will happen if I choose a totally different range which is not a part of our wired LAN.
THX.
