RAP mode and PPTP tunelling
Is it possible to set up a tunnel on an AP in RAP mode, connecting the AP to an artibitary server?
We have a bunch of 205H APs which we would like to connect to a server that needs access to their local networks.
Also, is it possible to configure port forwarding on individual devices?
Daniel
Valued Contributor II
Re: RAP mode and PPTP tunelling
HI Friend,
Aruba APs always terminated on controller and user traffic will be processed by the Controller. APs ( Campus AP or RAP ) can not form any tunnel with other than Aruba Controller.
Please feel free for any further query on this.
Cheers,
Venu Puduchery,
Thank you!
How about port forwarding?
