Frequent Contributor II
RAP through WiFi connection
Hi all,
I am trying to setup a RAP-3WN. It works fine if we connect it to controller through ethernet, but if I try to connnect it to controller through WiFi Uplink it doesn't work.
Is this a well-known situation? Is not possible connect a RAP to a controller using RAP WiFi interface?
Massimo
Massimo Gallina
Telecommunications engineer - ACMP2013
Re: RAP through WiFi connection
As far as i aware.
  • You can only use 3G/Wired enviroment in order to establish RAP connecitivy to your controller.
  • Its not recommnded / U CANT - use Wi-Fi uplink or other RAP eth-port to connect your RAP to the controller.
Thanks for the reply kdisc98! :smileyhappy:
Is there any Aruba documents about this?
Massimo Gallina
