Occasional Contributor I
RAP using FQDN to reach controller
In order to make changing the controller's IP easier in the future, I'm trying to get our RAPs to connect to it using the the FQDN instead of its IP.
I've set the servername and domainname environnement variables but the RAP picks up the DHCP's domainname and uses that instead.
Is there a way to get the RAP to ignore the domainname the DHCP server provides ?
John
Frequent Contributor II
Re: RAP using FQDN to reach controller
maybe this will help :
http://www.techrepublic.com/forums/discussions/dns-fqdn-works-hostname-does-not/
If you found my post helpful, please give kudos!
Thanks but that isn't much help here :-/
We use RAPs to extend the company's wifi network at sites we don't control.
I need the RAPs to ignore the DNS suffix provided by a DHCP server.
John
Try with a console cable to configure the domain name on the AP's
setenv domainname <domain>
saveenv // to save the config
boot // to reboot the AP
I already tried that but the domain name provided via dhcp seems to override that setting :-/
This email and any accompanying attachments are confidential. If you received this email by mistake, please delete
it from your system. Any review, disclosure, copying, distribution, or use of the email by others is strictly prohibited.
