MVP
RAP whitelist not showing?
Doing a new controller install here (M3mk1 with 6.1.2.7) and I'm missing the Remote AP whitelist screen from the Configuration -> AP Installation menu. The tab is simply not there. Cleared my browsers cache without result.
Any idea's where its gone? Is a license required for it?
Koen (ACMX #351 | ACDX #547 | ACCP)
Re: RAP whitelist not showing?
There should be no licenses required for it.  Do you have any licenses on the controller, at all?
MVP
found my issue, you DO need licenses.. AP licenses or it simply does not show up apparently.
Thank you for confirming that.
