RAP with Hotel Captive portal
Any guide to show how to configure the RAP to bypass the Hotel Captive Portal authentication? I know the RAP can be configure as tunnel mode to over come this issue but i need the documentation guide.
Re: RAP with Hotel Captive portal
Please see the knowledgebase article here:  http://kb.arubanetworks.com/cgi-bin/arubanetworks.cfg/php/enduser/std_adp.php?p_faqid=511
http://community.arubanetworks.com/t5/Controller-Based-WLANs/How-do-I-configure-a-backup-SSID-in-a-hotel-scenario/ta-p/177662
You can also plug E0 into the hotel LAN and a laptop into E1 and you'll get to the hotel's captive portal.  Once you're through the RAP will be able to make its VPN connection to its controller.  That is, unless the hotel blocks UDP 4500.
The link no longer works.
