Frequent Contributor I
RAP2 vs RAP5 technical specs
Does anyone have any technical specs on the RAP2 vs RAP5 or RAP5WN?
I am curious what the cpu and memory differences are on each.
Thanks.
Re: RAP2 vs RAP5 technical specs
Thanks.
I do not see that information in any of the specifications documents.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
